  • #42556
    Nikola Merazzi
    Threads: 0
      Question about relinking maps in a 3D models library using Project Manager and Batch Render & Relink
      Issue:
      I’ve been relinking all the maps using Batch Render & Relink, but after relinking, the status shows as ‘Found’ instead of ‘OK’.
      When I drag and drop the models into the 3ds Max viewport, they come in without the maps, so I have to relink again—leading to a lot of wasted time.
      Temporary Solution:
      The workaround I found is, after using Batch Render & Relink, I need to manually open each model in Project Manager, go to Asset Tracking for each one (since I can’t do this for multiple files), press F3 (Resolve Path), which changes the status from ‘Found’ to ‘OK’ instantly. Then, after saving, the maps appear when I drag and drop the model.
      However, this process is tedious since I have to do it for each model individually—right-clicking on each one, going to Asset Tracking, selecting all maps with Ctrl + A, pressing F3, and then saving the changes.
      Question
      Has somehow that I can resolve paths all in one goal after relink all maps?
      Make any sense my question? Thanks!
  • #42561
      Check if you turn on the option “Recursive subfolders” and add valid paths for search in
