- September 20, 2023 at 19:54 #39823
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Soon I will release an update that should solve some issues with slow file display when using the method you are using.
Ultimately, the user should choose how it is more convenient for them to organize folders.
Thank you for your feedback! - September 21, 2023 at 00:54 #39826
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Please try version 3.23.42
Auto-updater will be triggered in a few days if there’s no critical issue found. - September 21, 2023 at 16:32 #39834
Theo De Carvalho Barbosa
ParticipantPosts: 2Threads: 14Joined: May 2021Hi.
I leave PM opened all day yesterday to process database. Nothing changes in terms of speed. I think my organization is not compatible with PM system. :(
Well, maybe reset or delete database to refresh all thumb and folder structure may work. I dont know how to do this properlly…
Meanwhile I tested another asset mananger (that I dont like so much as yours) to test speed. It´s work for see thumbnails and speed is fine, like browser. Works fine to see and navigate. But I noticed one difference: It needs to scan to match all .max files with related thumbnail. After scan, works fine. In help they explain: It needs to scan to link exactly to avoid speed flaws. (if you need, I post link)
Well, Im gonna wait for some sollution in future update. I dont have plans to explode my folders and join all max with thumbs. It wont work for me to organize in a batch.
Anyway, thanks for support and attention.
Cheers.
- September 21, 2023 at 16:37 #39835
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Did you try version 3.23.42?
As I see you did not download the latest version - September 21, 2023 at 16:51 #39836
ParticipantPosts: 2Threads: 14Joined: May 2021I´ll download it now. My version is 3.23.40. Check Update direct from PM is: “You are using lastest Project Mananger version (3.23.40).” No update available
I´ll download it manually. Thanks
- September 21, 2023 at 17:08 #39837
ParticipantPosts: 2Threads: 14Joined: May 2021Nothing changes in 3.23.42. BUT….
I tested now with PM not maximized on screen and sow some errors in Maxcript Listener. I´ll paste here:
1: SQLite error (5): database is locked in “SELECT name FROM sqlite_master WHERE type=’table’ AND name !=’sqlite_sequence’;”
2: SQLite notice (283): recovered 17 frames from WAL file C:\Users\xxxx\AppData\Local\Autodesk\3dsMax\2022 – 64bit\ENU\scripts\Kstudio\ProjectManager_3\Settings\AssetSQLiteCache.db-wal
2: SQLite error (17): statement aborts at 213: [SELECT filedata.ID as Parent_FileID, GROUP_CONCAT(DISTINCT(directory.ID || ‘$’ || directorydata.Path)) as CategoryData,childFileData.ID as FileData_ThumbID, childFile.ID as ThumbnailI
- September 21, 2023 at 17:16 #39838
ModeratorPosts: 264Threads: 1283Joined: Aug 2009It’s not important messages, you can ignore them
Please check your email
