- October 17, 2019 at 00:08 #21087
Ramon Aranguren
ParticipantPosts: 6Threads: 11Joined: Aug 2018The migration from PM2 was not flawless at all, up to the point that I was not able to migrate settings, collections or any database, actually PM3 deleted everything when pointed to the old database and settings folder… what a waste of time and effort.
Plugin version: 3.06.97
3ds Max version: 3ds Max 2020.2
Renderer: Fstorm Render - October 17, 2019 at 00:12 #21097
ModeratorPosts: 264Threads: 1283Joined: Aug 2009If plugin didn’t update database automatically you can do this himself.
Open preferences dialog => tab “DataBase” => press the button “restore database” => “Load from” and specify path to location of your previous database ( you can search for file “ProjectManager.db”).
Select database in list and press the button “Restore database”.
- October 17, 2019 at 00:15 #21098
pixelknot
ParticipantPosts: 0Threads: 1Joined: Nov 2018Thank you alex will try and report
- October 17, 2019 at 02:46 #21102
Ramon Aranguren
ParticipantPosts: 6Threads: 11Joined: Aug 2018It does work like a charm, but beware of having a backup before installing it, because it could screw you over really quick
- October 30, 2019 at 18:51 #21833
Jorge Fierro
ParticipantPosts: 2Threads: 4Joined: Oct 2017I can’t no longer sort by tags in V3 , is there away to update tags to comments or get back the tags?
- October 30, 2019 at 18:55 #21835
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Please see the section “Convert Descriptions & Tags“
- October 30, 2019 at 20:42 #21865
Jorge Fierro
ParticipantPosts: 2Threads: 4Joined: Oct 2017Awesome!, I knew you’ll have a simple solution , Thanks Alexander!
- October 30, 2019 at 18:59 #21836
Ramon Aranguren
ParticipantPosts: 6Threads: 11Joined: Aug 2018Alex, one bug that I was seeing is that the don’t use delete button setting would reset itself to off was not working it would deactivate itself
[Resolved]
- October 30, 2019 at 19:06 #21837
ModeratorPosts: 264Threads: 1283Joined: Aug 2009You right – this doesn’t work when you set this on install. Soon I’ll fix this.
But this option works from the Preferences dialog.
