Viewing 9 posts
  • #24024
    Man Mars
    Threads: 12
      Just additional screenshot for my topic: this is full folder structure.
    Plugin version: 3.07.82
    3ds Max version: 2018
    Renderer: corona
  • #24032
      PM scans only nearest directories for missing maps on merging.
      So you should move directory to subdirectory (to folder “MT pm v 20” ) or inside the directory “MT pm v 20 forest pack…”.
      Or use the Bath Render & Relink for mass re-linking your 3d assets.
  • #24036
    Man Mars
    Threads: 12
      1/ I’ve used folder “MT pm v20” as directory in PM, but the problem remains.
      2/I’ve tried using Batch render & relink. But it run too slow in my opinion. So I stop it and go to the next way.
      3/ Moving all files in the “MT pm v20” out and use “MT pm 20 forest pack…” as directory. It works now. The inconvinient thing is: this folder structure is existing before, from Maxtree. So I have to change all other volumes, too. This is not really easy, because the asset library is also used by my colleagues.
  • #24038
      If PM will search for missing maps deeper always on merging, this will make the merging process very slow.
      Do you have an idea of how to determine related directories faster?
      2/I’ve tried using Batch render & relink. But it run too slow in my opinion…
      Do this once for all your 3d library. Just run this operation in the evening and get the result in the morning.
  • #24048
    Man Mars
    Threads: 12
      Thank you for fast respone!
      I’m not coder, so I ‘m not sure, just my thinking:
      (1)If I setup the map directory in max “Configure User Path> External file” only once, I can used it for all related model.
      (2)Time consuming because B&R has to open each .max file to relink. So, from (1), does it possible if it just relink only one file in the same folder (means the same volume), then it remember that relinked map directory and applies it to all other files?
      May be this is weird idea though.
  • #24052
      1. A big number of paths in  “Configure User Path> External file” also can make the merging process slow.
      2. There is another way exists for relinking maps faster but it less trusty. And this method cannot divide maps from output paths. I’ll think about introducing this method.
        Also, I’ll think about the ability to specify relative paths for searching maps on fly.
        Ok – thanks for ideas!
      PS. Now you can try to use a method that described in the topic Asset Management Using Project Manager
  • #24054
      Also, you can use the method described in section Relink using “Set Path”
      But in your case, I think that batch relinking is a more convenient way at this moment.
  • #24076
    Man Mars
    Threads: 12
      Thank you. I let my computer run some hours and everything works fine now.
      By the way, I have no idea why some assets do not show texture after merged. There is third plugin help to do that, but it’s not really convinient. Can I set up to show texture as default with PM or some how?
  • #24084
Viewing 9 posts
