- June 29, 2022 at 10:04 #35811
Thomas C
ParticipantPosts: 14Threads: 45Joined: Mar 2022Hi Alex,
Thanks for this great plugin, I love it!
One thing I noticed though, is if I have multiple 3ds Max sessions opened, and I run Project Manager on more than one session simultaneously, it’s impossible to have the ‘View image (space)’ feature working on every 3ds Max sessions. It can work only on one session at a time. If I want to use ‘View image (space)’ on another 3ds Max session, I first have to close all other Project Manager programs on other 3ds Max sessions.
Is it a bug, or is there a workaround for this at the moment?
Thanks a lot for your support!
Tom
Plugin version: 3.18.24
3ds Max version: 2022.3.3
Renderer: Corona 8 Hotfix 1 - June 29, 2022 at 11:12 #35813
ModeratorPosts: 264Threads: 1283Joined: Aug 2009This issue will be fixed in the next version.
Thanks for your feedback!
- June 29, 2022 at 12:10 #35815
Thomas C
ParticipantPosts: 14Threads: 45Joined: Mar 2022You’re welcome Alex, thanks!
- June 30, 2022 at 07:48 #35819
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Please try version 3.18.31
Auto-updater will be triggered in a few days if there’s no critical issue found. - June 30, 2022 at 09:59 #35824
Thomas C
ParticipantPosts: 14Threads: 45Joined: Mar 2022You are amazing Oleksandr, thanks!
- July 15, 2022 at 09:29 #35964
Thomas C
ParticipantPosts: 14Threads: 45Joined: Mar 2022Hi Oleksandr,
I installed last Project Manager version 3.18.34 but the issue does not seem to be fixed.
Thank you for your support.
- July 15, 2022 at 10:37 #35968
I understood the problem. Currently it works correctly for running on the different versions of 3ds Max. But doesn’t work on running several sessions of the same 3ds Max version.
This will be fixed with the next update.
- July 15, 2022 at 10:59 #35969
Thomas C
ParticipantPosts: 14Threads: 45Joined: Mar 2022All right, cool.
Thanks Oleksandr!
