- June 19, 2025 at 17:01 #45032
andreu
ParticipantPosts: 1Threads: 3Joined: Apr 2025Hi,
When an object in uncheck as “Renderable” in the Object Properties window in 3DS Max, it seems like Project Manager disregards the object when importing it.
We have scenarios on our library where we would like these none-renderable objects to be imported as well. They are base object for Forest Pack setups, etc.
Could this be possible in some way?
Plugin version: 3.39.34
3ds Max version: 3ds max 2023
Renderer: Corona - June 19, 2025 at 17:03 #45036
ModeratorPosts: 264Threads: 1285Joined: Aug 2009Use these filters to manage excludings
- June 19, 2025 at 17:16 #45037
andreu
ParticipantPosts: 1Threads: 3Joined: Apr 2025Thanks Oleksandr for the quick response!
The only options that could be affecting this based on your feedback is “Skip empty geometry”, but that is not the case, plus I have it unckeck already.
The geometry has faces. It’s just that is check as none renderable in the Object Property dialogue.
- June 19, 2025 at 17:20 #45038
andreu
ParticipantPosts: 1Threads: 3Joined: Apr 2025Object with renderable “uncheck” do not import using Project Manager.
However this is an interesting feature to import Forest Pack Objects that scatter on top of a “none renderable” object, so when you render you only see the scattered result but not the base object.
- June 19, 2025 at 17:48 #45039
ModeratorPosts: 264Threads: 1285Joined: Aug 2009This option. I should rename it for clarity
- June 19, 2025 at 18:03 #45040
andreu
ParticipantPosts: 1Threads: 3Joined: Apr 2025This is it.
I understand the challenge to find the right words there.
Thanks Oleksandr!
