  • #16141
    Threads: 21
      I want to make my hdri library, but i want to use my own modifications on the hdris using a corona output node, the thing is when i save the hdri it does not save it as An enviroment map, instead it saves as a corona shader, so when i plug that map into the enviroment it comes as a shader with all the settings scrambled, is there any solution to this, i attach a video to illustrate things up.
      https://youtu.be/D8v_YAJrpK0
    Plugin version: 2.89
    3ds Max version: 2016 sp4
    Renderer: corona
  • #16145
      Hello Daniel
      TextureMap saved properly, but as i saw you want place it into MatEditor as map.
      Use the button “Place to Material Editor” like on picture below.
      In the next version I’ll add ability to place a textureMap to ME as is by holding the SHIFT key.
      Thanks for your question.
  • #16148
    Threads: 21
      Perfect Alex!
      many THX!
