- March 24, 2020 at 17:43 #27180
3dwannab
ParticipantPosts: 4Threads: 15Joined: Sep 2019Here are the filename of the max files and the images I want to auto-assign.
CGAxis 001 – Plants 002_Corona.max
CGAxis 001 – Plants 001_Corona.max
Is it possible to add an option to the new feature for regular expressions or is my naming scheme possible with the current features?
So a filter could be used such as (which has (?i) for turning off case sensitivity so that the filenames case doesn’t matter):
(?i)(_render.*|_corona.*|vray.*)(\.)(jpg|png|max|obj)$
As you can see the jpg and the max files both have the same final name so that PM could then match the same image files to the max files as in this example.
Plugin version: 3.09.15
3ds Max version: 2020 - March 24, 2020 at 17:48 #27186
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Switch to Fuzzy search and use the next text in the “Ignore”
<regex:\d{3}(_render|_corona|\s\d*|wire)>
- March 24, 2020 at 18:28 #27187
3dwannab
ParticipantPosts: 4Threads: 15Joined: Sep 2019I did try yours and one of mine which resulted in all the previews getting assigned to each max file
My regexp:
<regex:(_Render.+|_Corona.+)>
See attached the result (along with a suggestion for showing the number of preview if they exist)
- March 24, 2020 at 18:39 #27188
3dwannab
ParticipantPosts: 4Threads: 15Joined: Sep 2019 - March 24, 2020 at 19:23 #27189
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Please run this command in the Command Promt and send a file “myfiles.txt” to support@3d-kstudio.com
dir c:\path_to_models /s/b ->myfiles.txt
- March 24, 2020 at 19:27 #27190
3dwannab
ParticipantPosts: 4Threads: 15Joined: Sep 2019Done. What in regards the numbers of the previews. Is that something you’d consider?
- March 25, 2020 at 14:58 #27195
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Version 3.09.18 gains the ability to specify the level of similarity of filenames.
In your case the ignore should be next: <regex:_corona|(_render\s\d*|wire)>
And Difference should be set to “Similar“.
I’ll add this to the feature list.
- March 25, 2020 at 20:27 #27202
3dwannab
ParticipantPosts: 4Threads: 15Joined: Sep 2019Thanks, that’s working but it has brought up a new issue for me.
It is assigning the _wire images to the first image in the preview. How could I get it so that the _wire images get assigned last? The order is reversed as to what File explorer is showing.
This is the order as shown in the file explorer.
- March 26, 2020 at 01:56 #27206
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Ok. Maybe I should add the new block like “Order rules” to the settings.
- March 26, 2020 at 01:59 #27207
3dwannab
ParticipantPosts: 4Threads: 15Joined: Sep 2019Yes, a-z and z-a and whatever you decide. Cheers.
- April 10, 2020 at 14:15 #27377
3dwannab
ParticipantPosts: 4Threads: 15Joined: Sep 2019Hi,
Just wondering if you have added the sorting in the latest release? 3.10.10
Thanks for adding the numbers for the previews.
- April 30, 2020 at 11:08 #27706
ModeratorPosts: 264Threads: 1283Joined: Aug 2009This feature in development.
Thanks for your idea!
- November 18, 2020 at 10:02 #30198
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Project Manager version 3.13.00 gains the ability to sort and exclude files from the Gallery
These settings apply automatically on auto assigning. Also, you can apply these rules for selected items or to all items in the database.
You can download this version from the dashboard.
Thanks for your ideas!PS. Type words in quotes.
<_wire><_ambient><word3><etc>
[Resolved]
