Viewing 6 posts
- May 31, 2018 at 13:42 #15996
jarfley
ParticipantPosts: 7Threads: 12Joined: Apr 2018When you try to delete a file, the confirmation panel is hidden
- May 31, 2018 at 13:44 #15997
ModeratorPosts: 264Threads: 1283Joined: Aug 2009This options is same as in system.
You can turn on confirmation in the system’s recycle bin.
- May 31, 2018 at 14:40 #15998
jarfley
ParticipantPosts: 7Threads: 12Joined: Apr 2018There has been a moment that the confirmation panel
it was hidden behind the main interface and the deletion could not be confirmed.
I do not know what happened, but now it works well. - May 31, 2018 at 15:03 #15999
jarfley
ParticipantPosts: 7Threads: 12Joined: Apr 2018hidden panel behind the main
- June 1, 2018 at 13:45 #16005
jarfley
ParticipantPosts: 7Threads: 12Joined: Apr 2018I have reinstalled and at the moment it is going well.
- June 1, 2018 at 13:50 #16006
ModeratorPosts: 264Threads: 1283Joined: Aug 20093ds max has such an “illness” when some child windows are hiding behind the parent windows.
Thank you for drawing my attention – if possible, I will correct it.
Viewing 6 posts
