Viewing 5 posts
  • #27038
    Jui-Ting Wang
    Threads: 0
      Could I use  Batch Render&Relink to change file path  from server A to server B?
      I copy the project from server A and paste it on server B.
      So these two projects have same strcut of folder.
      I only want to relink the assets path or replace the Prefix on Server B.
      Any function of projectmanager can batch like this demand?
      example:
      \\serverA\Character01\       >>>>    \\serverB\Character01\
    Plugin version: 3.08.74
    3ds Max version: 2018
  • #27047
    Threads: 1267
      You can use the “Find&Replace” feature
      Or new feature for the 3rd version: Advanced Asset Renamer
      Find&Replace function for batch processing multiple files in the wishlist for the future versions.
      Have a great day and always welcome with your questions!
  • #34129
    Piotr Duda
    Threads: 2
      HI,
      I’m trying to use this function but it doesn’t work in such situations:
      ProjectManager
      • trying to replace bitmaps of Xref objects
      Batch and Relink:
      • trying to replace bitmaps of opened file
      • trying to replace bitmaps of the Batch folder
      Trying replace local D with (the same comp) D as a network path TRX3060:
      screen
  • #34130
    Piotr Duda
    Threads: 2
      I tried to EDIT the last post but there were some issues with that.
      I managed to Batch relink, the source folders should be thicked of course.
      However, I’m not sure if there is a limitation with changing paths in Xref objects in the Project Manager in the Assets tab?
    • #34158
      Threads: 1267
        In most cases, these limitations depend on the using renderer.
        What exactly way for changing paths are you mean?
Viewing 5 posts
