- March 12, 2020 at 09:53 #27038
Jui-Ting Wang
ParticipantPosts: 1Threads: 0Joined: Mar 2020Could I use Batch Render&Relink to change file path from server A to server B?
I copy the project from server A and paste it on server B.
So these two projects have same strcut of folder.
I only want to relink the assets path or replace the Prefix on Server B.
Any function of projectmanager can batch like this demand?
example:
\\serverA\Character01\ >>>> \\serverB\Character01\
Plugin version: 3.08.74
3ds Max version: 2018 - March 12, 2020 at 10:00 #27047
ModeratorPosts: 264Threads: 1282Joined: Aug 2009You can use the “Find&Replace” feature
Or new feature for the 3rd version: Advanced Asset Renamer
Find&Replace function for batch processing multiple files in the wishlist for the future versions.
Have a great day and always welcome with your questions!
- December 4, 2021 at 10:15 #34129
Piotr Duda
ParticipantPosts: 0Threads: 2Joined: May 2017- trying to replace bitmaps of Xref objects
- trying to replace bitmaps of opened file
- trying to replace bitmaps of the Batch folder
HI,
I’m trying to use this function but it doesn’t work in such situations:
ProjectManager
Batch and Relink:
Trying replace local D with (the same comp) D as a network path TRX3060:
- December 4, 2021 at 10:26 #34130
Piotr Duda
ParticipantPosts: 0Threads: 2Joined: May 2017I tried to EDIT the last post but there were some issues with that.
I managed to Batch relink, the source folders should be thicked of course.
However, I’m not sure if there is a limitation with changing paths in Xref objects in the Project Manager in the Assets tab?- December 7, 2021 at 13:20 #34158
ModeratorPosts: 264Threads: 1282Joined: Aug 2009However, I’m not sure if there is a limitation with changing paths in Xref objects in the Project Manager in the Assets tab?
In most cases, these limitations depend on the using renderer.
What exactly way for changing paths are you mean?
