Viewing 5 posts
  • #18127
    yuzhu kang
    Threads: 3
      I’m sorry, my English is not very good, I’m in the 3 dsmax2018 export VRmesh file, use 3 dsmax2017 load VRmesh model, merge lost material, 3 dsmax2018 work normally.
    Plugin version: 2.92
    3ds Max version: 3dsmax2018
  • #18129
    Threads: 1285
      This occurs because you export to Proxy using 3ds Max 2018.
      Materials which saved with version 2018 can’t be load in 3ds Max 2017.
  • #18130
    yuzhu kang
    Threads: 3
      Thank you, I see, there is a problem, I pulled into the model, don’t automatically hide the ProjectManager window.
  • #18137
    yuzhu kang
    Threads: 3
      Place the object tool F7 failure
    • #18138
      Threads: 1285
        Please  update to latest version.
        As I see you use the version 2.92
Viewing 5 posts
