- March 1, 2017 at 21:36 #10824
Loek Meenhorst
ParticipantPosts: 1Threads: 0Joined: May 2012If i recall correctly, in previous version I used to be able to drag folders from my windows explorer to PM.
Now I can’t anymore, (on 2 computers with latest version) and have to right click, choose add folder etc. pretty annoying.
Could it be a .net framework 4.6 problem in windows 10 maybe?
Also, when I drag a hdri into the viewport, the hdri is only added to the environment slot.
didn’t pm also used to create a vray dome light with the associated hdri, or wasn’t this the case?
Plugin version: latest stable version
3ds Max version: 3dsmax 2016 no sp
Renderer: Vray 3.4.03 - March 3, 2017 at 17:33 #10841
ModeratorPosts: 264Threads: 1284Joined: Aug 2009Thanks for your feedback and wishes.
…able to drag folders from my windows explorer to PM.
But i can’t reproduce this issue.
Are you tried drag a folder from network or local path?
Whereto did you drag it?
To treeview panel, to another directory, to catalog or to favorites folder?Also, when I drag a hdri into the viewport, the hdri is only added to the environment slot.
Maybe you want what hdri also assign to Vray render reflect/refract slot?
…create a vray dome light with the associated hdri
You can simple assign HDRI to desired slot of Vray Light by dragging.
