- April 14, 2021 at 18:33 #31766
- Adds an ability to batch export 3d files to 3ds Max file format
- Supports converting Vray and Corona Proxy to 3ds Max file format
- Supports to specify 3ds Max version on export 3d files to 3ds Max file format
- Adds an ability to set hotkeys for programs in the "Open with..." menu items list
- Renames "Asset Files" tab to "Asset Tracking"
- Fixes some minor issues with ProxSi
- Fixes an issue with converting some objects to proxy
The new version of Kstudio Asset Browser allows to batch export 3D models to 3ds max format. Vray and Corona Proxy will be converted to a standard mesh. The customer can also specify the version of 3ds max to save.
Just select the files to export and use the “3Ds Max version” submenu in the “Export to:” menu.You can specify either an absolute or relative path to the exported files.
Now customers can specify a shortcut for applications in the menu “Open with”.
Just add any desired application to the list and assign the desired shortcut using the menu Customize => Customize user interface.
You can see the full list of changes and fixes below.
Related to "Project Manager version 3.14.32"
