  • #29409
      Project Manager - Display assets from multiple Favorites
      With Project Manager version 3.12.17, you can manage your Favorites even better – set colors, view content in several Favorites at once, sort Favorite directories manually or alphabetically.
      Also, adding a large number of assets to Favorite using the drag & drop method has been significantly accelerated.
      And now a little bit more details about new features in the asset manager plug-in.
      Interface
      Colorize. Display content from multiply Favorites
      The new version allows set colors for Favorites as well. Just select one or more Favorites for coloring and set the desired color.
      Also, the new version gains the ability to display the contents of several Favorites at once. Use the settings for Favorites to display the contents of sub-favorites.
      If multiply favorites are selected only the contents of the selected folders will be displayed.
      Note that the Favorites display is significantly accelerated.
      Sort Favorites alphabetically and manually
      You can also use the settings panel to sort the favorites alphabetically. (To sort manually, uncheck “Sort by name” and use CTRL+UP/CTRL+DOWN to move favorites above or below)
      All this is applicable to any type of asset including materials.
      TreeView Settings
      Mass Rename tool
      Using the F2 hotkey to rename assets has been slightly changed. If one file is selected, you can rename it by pressing F2.
      If you select multiple assets, pressing F2 will open the Mass Rename tool.
      Project Manager - 3D Asset Browser - Advanced Asset Renamer
      Miscellaneous
      Adds an ability to optimize database from the Preferences dialog. Also, this new feature allows removing missing files and directories from the database.
      Optimize Database
      Fixes some issues with lighting and camera views in some cases when rendering previews for 3d models
      • Adds an ability to colorize Favorites
      • Adds an ability to display sub-folders in Favorites
      • Adds an ability to display assets from multiple selected Favorites
      • Adds an ability to sort Favorites alphabetically
      • Adds an ability to optimize database from the Preferences dialog
      • Speeds-up adding files to Favorites using drag&drop
      • Adds support to Corona 6
      • Opens the "Mass Rename" tool using F2 hotkey when multiply assets are selected
      • Fixes an issue with upgrading large databases to 3rd version
      • Fixes some issues with lighting and camera views in some cases when rendering previews for 3d models
      • Fixes an issue with dragging materials/textures to multi/sub-object materials in 3ds Max 2021
      • Fixes a bug with auto-updating
      • Some optimizations & speed improvements
      Related to "Project Manager version 3.12.17"
