- February 19, 2018 at 12:05 #14811
ModeratorPosts: 264Threads: 1283Joined: Aug 2009- New default render-presets. Adds default presets to Final Render, Octane, Redshift, Fstorm and Arnold renderers
- Adds an ability to set 3ds Max version for save models from scene to library
- Merge as xRef objects now uses settings from 3ds Max for merging models (such as merge materials, modifiers, tracks and etc. )
- Adds an ability to change view of painted models between “Display as Box” and default view (active viewport display mode)
- Adds an ability to merge models as SmartRefs
- Now placing on HomeGrid always allowed [Object Place&Paint]
- More accurate fitting of objects to the view when rendering previews
- Adds an option “Fit to Dummy” to render setting
- Adds an ability to Interactive Render of BVH animation files
- Adds an ability to create Biped from .CSM files
- Adds support to Final Render trueHybrid
- Native preview for Final Render proxy files (.fpx)
- Adds an ability to paint using merged nodes
- New capabilities with placing merged objects in scene: place on selection, on all scene objects or home grid
- Adds an ability to rendering previews using Vray Frame Buffer ( available for Vray 3.20.02 and above )
- Fixes a problem with creating a Proxy when both renderers are installed simultaneously – Redshift and Octane
- Fixes an issues with display the version of 3ds Max for some 3ds Max files
- Fixes an issues with add/remove custom extensions to display files
- Fixes an issue with set custom view for rendering previews defined into drop-down “View”
- Fixes a bug in FStorm Render when 3Ds Max crashed on trying to access Bitmap FStorm properties
- Fixes an issue with rendering preview for models without studio
- Fixes a bug with extremely slow placing objects using the ‘Object Place&Paint’ tool
- Fixes a scaling for BVH files when interactive rendering
- Fixes a bug with crashing the 3Ds Max if studio doesn’t contain the ‘SceneDummy’ object
- Fixes an issue with placing merged objects on scene objects
- Fixes an issue when user can place a merged objects too far from the origin
- Fixes an issue with display some image files in the listview when running different Kstudio’s plugins at same time
- Fixes an issue with scaling objects on rendering a preview when an option “Fit view to nodes” turned off
- Fixes a bug with missing IES files into “Favorities” folders
- Fixes an issue with opening user scripts for edit from “Manage Custom Menus” dialog
- Fixes an issue with using a full and demo version of different Kstudio’s plugins at same time
- Fixes a compatibility with plugins which use a old version of NLog library
- Fixes an issue with slowdown of loading directories when complex scene is open into 3Ds Max
- Fixes a bug when in some situations window not drawn properly
- Fixes the bug for 3Ds Max 2018 with crashing the 3Ds Max when user try delete some files
- Fixes an issue for version 1.65.40 with fitting a camera view to nodes when camera has invalid target
- Fixes the issue with rendering preview for .BIP and .BVH files
- Fixes the issue with rendering preview when using the custom studio with VRayPhysical camera
- Fixes the issue with found compatible renderer for some models
- Other some changes and speed improvements
- Supports only to x64-bit system
$22.00Add to Cart
Related to "Models Manager v.1.72.04"
