- April 10, 2021 at 00:03 #31695
Nate Norbie
ParticipantPosts: 6Threads: 5Joined: Oct 2017::Plugin installs fine but when I go to add a directory I get this error with Net Framework box with these details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.************** Exception Text **************
System.MissingMethodException: Method not found: ‘System.String ManagedServices.MaxscriptSDK.ExecuteStringMaxscriptQuery(System.String)’.
at Kstudio.SweepProfile.SweepProfileForm.btnAddDirectory_Click(Object sender, EventArgs e)
at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
at System.Windows.Forms.ToolStripButton.OnClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ToolStrip.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)Plugin: -1
- April 10, 2021 at 00:08 #31700
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Sweep Pro version 1.00.42 is supported to 3ds Max 2022.
Just upgrade to the latest version
- April 10, 2021 at 18:12 #31702
Nate Norbie
ParticipantPosts: 6Threads: 5Joined: Oct 2017I am using 1.00.42 (latest) and getting this error. Plugin works out of the box but when I try and add other profile folders (plus icon) it errors out with about Microsoft .Net Framework error.
- April 10, 2021 at 21:38 #31703
ModeratorPosts: 264Threads: 1283Joined: Aug 2009The bug is fixed. Please update to version 1.00.44
Thank you!
- April 11, 2021 at 04:49 #31705
Nate Norbie
ParticipantPosts: 6Threads: 5Joined: Oct 2017Wow, that was fast! You rock! Thanks!
