Viewing 6 posts
  • #9901
    Robert Freitag
    Threads: 0
      Hello, I’ve tried to submit this request via Bug report, but I get an error message when I do so. This is why I’m posting it here:
      I want to batch relink and render thumbnails of a lot of max files that already contain cameras that would be perfect for thumbnails in project manager.
      Now when I check ‘Render Default scene view’ in the ‘Render Thumbnails Preferences’, It still renders the Top-Front-Right view which is default.
      Even though there is a camera in the scene that is active when I open the max file.
      Did I understand that checkbox wrong or is this a bug?
      Would it be possible to add “First Cam in Cam array” to the listbox in the options menu? Please also check out the Link below.
      Thanks
      -Robert
      LOOK AT ME
  • #9902
    Threads: 1285
      Add this script as post-open script for changing default scene view
      if PostScriptInfo != undefined and pathConfig.appendPath maxFilePath maxFilename == PostScriptInfo.MaxFile and PostScriptInfo.BatchMode =="Render" and viewport.GetCamera() == undefined do (
      	local cam = cameras[1]
      	if cam != undefined do
      		viewport.SetCamera cam
  • #9903
    Nicholas Dixon
    Threads: 2
      Are there any boxes that need to be checked for this to work?  I can’t seem to get it to work for some reason.  This script should just be a .ms file, correct?
  • #9904
    Threads: 1285
      Yes – this is a .ms file.
      I can check your script. Please attach it here.
  • #9905
    Nicholas Dixon
    Threads: 2
  • #9906
    Threads: 1285
      All right.
      If you have a problem with changing a view to camera please generate a bug report.
Viewing 6 posts
