Viewing 11 posts
  • #44175
    Vasil Baidashchuk
    Threads: 6
      info  from log
      Process directory: E:\textures\PBR textures\Poliigon Textures\Architectural\
      Process directory: E:\textures\PBR textures\Poliigon Textures\Architectural\FenceChainLink001\
      Process directory: E:\textures\PBR textures\Poliigon Textures\Architectural\RoofShingles002\
      Process directory: E:\textures\PBR textures\Poliigon Textures\Architectural\RoofShingles003\
      Process directory: E:\textures\PBR textures\Poliigon Textures\Architectural\RoofShingles004\
      Process directory: E:\textures\PBR textures\Poliigon Textures\Architectural\RoofShinglesOld001\
      Process directory: E:\textures\PBR textures\Poliigon Textures\Architectural\RoofSlateGreyNew001\
      Process directory: E:\textures\PBR textures\Poliigon Textures\Architectural\RoofSlateGreyOld001\
      Process complete in 0 sec. Generate 0 materials from 0 directories
    Plugin version: 3.37.75
    3ds Max version: 2024
    Renderer: v-ray
  • #44178
    Threads: 1285
      Try to reset PBR settings
  • #44180
    Vasil Baidashchuk
    Threads: 6
      I reseted and it does not work. I tried a lot different actions but rusult the same.
  • #44181
    Vasil Baidashchuk
    Threads: 6
  • #44182
    Vasil Baidashchuk
    Threads: 6
  • #44183
    Vasil Baidashchuk
    Threads: 6
  • #44184
    Vasil Baidashchuk
    Threads: 6
  • #44187
    Threads: 1285
      The updated PBR Material Generator 1.05 now supports suffixes, allowing you to ignore specific parts of file names when grouping textures.
      🔹 What does this mean?
      You can now specify a regular expression to ignore suffixes, such as _[0-9]*k, ensuring that textures are correctly grouped regardless of their resolution.
      “_[0-9]*K” is default value. You can add custom suffixes.
      Example:
      If you set the suffix to _[0-9]*k, the following files will be automatically grouped together:
      This helps avoid confusion with different texture resolutions and makes material organization more efficient.
      The update is available now! 🚀
      Thanks for your feedback!
      [Resolved]
  • #44188
    Vasil Baidashchuk
    Threads: 6
      Perfect!  It Works. Thank you so much for your rapid response.
  • #44277
    Step One
      When a texture is .jpg and an other .png or .tif the material does not incude this texture.
    • #44289
      Threads: 1285
        Version 1.12 has a new option “Group by extension”
Viewing 11 posts
