- February 19, 2018 at 11:52 #14809
ModeratorPosts: 264Threads: 1283Joined: Aug 2009- New default render-presets. Adds default presets to Final Render, Octane, Redshift, Fstorm and Arnold renderers
- Adds an ability to rendering previews using Vray Frame Buffer ( available for Vray 3.20.02 and above )
- Changes for API: The ‘PostScriptInfo’ is deprecated. For details see a file “BatchRendering Script Example.ms” in ‘presets’ directory
- More accurate fitting of objects to the view when rendering previews
- Adds an option “Fit to Dummy” to render setting
- Fixes an issue with set custom view for rendering previews defined into drop-down “View”
- Fixes a bug in FStorm Render when 3Ds Max crashed on trying to access Bitmap FStorm properties
- Fixes a bug with crashing the 3Ds Max if studio doesn’t contain the ‘SceneDummy’ object
- Fixes an issue with very slow relinking of materials in Corona 1.7
- Fixes an issue with scaling objects on rendering a preview when an option “Fit view to nodes” turned off
- Fixes some minor issues
- Fixes an issue with using a full and demo version of different Kstudio’s plugins at same time
- Fixes a compatibility with plugins which use a old version of NLog library
- Fixes a bug when in some situations window not drawn properly
- Fixes an issue for version 1.60.21 with fitting a camera view to nodes when camera has invalid target
- Fixes the issue with rendering preview for .BIP and .BVH files
- Fixes the issue with rendering preview when using the custom studio with VRayPhysical camera
- Fixes the issue with opening VrMat files with #Found status
- Fixes the issue with found compatible renderer for some materials
- Fixes some minor issues with rendering previews
- Fixes an issue with using the render settings from scene/studio
- Other some changes and speed improvements
- Supports only to x64-bit system
$15.50Add to Cart
Related to "Batch Render&Relink v.1.63.24"
