• Download the archive with the plugin
  • Unpack the archive
  • Open 3ds Max application
  • To install an MZP file in 3ds Max, you can use one of the following methods
    • Drag and Drop Method:
    • – Simply drag the MZP file from your file explorer and drop it into the 3ds Max viewport.
    • Using Menu:
    • – Go to the “Scripting” menu and select “Run Script.”
    • – Navigate to the location of your MZP file, select it, and press “Open.”
  • The installation will be automatically started
  • Follow the instructions on the screen to complete the installation
  • Generate the identification file, if you are the official client and you need a new license
  • In the 3ds max menu “Customize”>> “Customize User Interface”>> Category “Kstudio” choose the plugin and drag it to the Panel of the Instruments
  • Double-click the downloaded installer to install the plugin.
  • Install the “Fusion“, “Sweep PRO” or free version of the plugin “Sweep Profile
  • Unpack the archive with Mouldings.zip
  • Drag the “Install Sweep-Profile Shapes.mzp” into the 3ds Max viewport
  • Start the plugin (Fusion or Sweep Pro) and choose the directory with shapes on the top list of the plugin
  • By default mouldings are installed by path “%localappdata%/Kstudio/Sweep-Profile Shapes/”
You must be logged in to download the full version.
* Applicable to official customers only
Run the 3ds Max
Choose the menu-item “Activation” from the main 3ds Max menu “Project Manager” or from the plugin menu “Help”
Select the most suitable activation type
  • Run the 3ds Max
  • Run Sweep PRO plugin
  • An activation dialog will appear
  • Run the 3ds Max
  • Create the Fusion/Spline Flow/…/Add the Modifier..
  • To create an object, choose the Kstudio Category in the Create section on the Command Panel
    Fusion - create
  • Create the object in the viewport and switch to the Modify tab
  • Open the License rollout at the bottom and press the button License
    Fusion- Apply License
Insert the activation key received in the letter and click the button “Apply License”
Activate plugin
Note: Internet connection is required to use activation keys
If you have a problem with this activation type, use the second method – using identification file
1. Press the button “Generate identification file”
2. Login to dashboard using the same email you used for purchase
3. Upload the identification file, generated in the previous step, by pressing the “Choose File” button
4. Press the button “Send”
5. Download the license key from the dashboard.
Also, you will receive a copy of your license key to an email-box
6. Press the button “Apply License” and choose the downloaded license key
Kstudio plugins are used by freelancers as well as in studios of different sizes – from several employees to hundreds.
This feature simplifies the deployment of numerous installations into a large network.
This instruction applicable only for Project Manager
I recommend paying attention to utilities such as PsExec and PowerShell – with their help you can install the 3dsMax plug-ins and apply the license keys in a batch mode.
Using:
  1. Download and extract the archive SilentModeInstall.zip
  2. Copy the ZIP archive with the full version of the plugin into one folder with “AutoInstallStart.bat”
  3. Open “AutoInstallStart.bat” and uncomment/add a valid path to 3dsMax.exe
  4. Write activation keys to the file “ActivationActivationKeys.txt”
  5. Run “AutoInstallStart.bat” using PsExec/PowerShell or manually on each computer
Download example: SilentModeInstall.zip
You can use a single identification file to obtain licenses for various plugins.
For instance, you can generate an identification file for Project Manager and use it also in the slot for generating a license for Spline Flow
How to Distinguish Between the Full and the Demo Version You Downloaded and Installed?
Before activation, do not forget to install the full version of the plugin
(the title shouldn’t contain the word Demo)
To determine if you have downloaded and installed the full version or the demo version, here are some key points to consider:
1. Activation: The demo version cannot be activated. If you have downloaded the demo version, activation will not be possible.
2. File Name: The archive containing the demo version will include the word “Demo” in its name.
3. Installation and Launch: During installation or when launching the plugin, the demo version will display the word “Demo” next to the logo.
4. Full Version: If there is no “Demo” label on the logo, but you see the “Demo” label over files, it means you have the full version which requires a license key for activation.
Full Version
Full Version
Demo Version
Demo Version
Note: Please use the latest updates for your version of 3ds Max
3ds Max Updates & Service Packs
See Also:
