  • #9892
    Threads: 1282
      Sometimes some users receive a message “Unable to create copy/move destination directory…” when trying install scripts.
      Unable to create copy-move destination directory
      As a rule, this issue occurs when a user changed a default directory for the user profile.
      By default a directory of user profile located
      by path “C:\Users\<USERNAME>\AppData\Local\Autodesk\3dsMax\20XXX\ENU“.
      But user can change this path to one directory with 3ds Max installation directory using the “InstallSettings.ini” file.
      But by default, this directory requires administrative privileges.
      So if you changed a default directory then you also must add the capability to users for reading and writing to 3ds Max installation directory.
      For fixing this issue select the 3ds Max installation directory and choose from explorer menu the menu item “Properties” and add the capability “Full control” for all users.User capability
      See another solution here
      Windows 10 troubleshooting (Permissions Issues section).
  • #28645
    somar alhussien
  • #35663
    paioneta
      I just Run the program (3dMAx) as administrator ad every thing worked just fine
  • #38838
    Maruf Madiyarov
      Thanks a lot! helped me
