Viewing 6 posts
  • #16602
    uluw B
    Threads: 0
      Project manager’TAG is not enough efficiency to use,like a plant model I may tagged them differently,and wouldn’t change local paths.
      Connecter’s tags is perfect but I more like use project manager.
      Wish could have TAGs system
  • #16615
      Favorites works like tags and allows to grouping files.
      Also unlike of connecter the Favorites allows to grouping directories.
      In version 3 the Favorites will be move to separate panel and allows to use several directories on top level.
  • #17829
    Nazarii Vovk
    Threads: 11
      Hi Alex. What will happen to old tags in version 3? Will I need to retag them? Also, will there be a popup when typing a tag, like IG has?
    • #17832
        After installing 3rd version you can convert tags and description to new format.
        Tags will be stored in database and displays as on picture above.
  • #17830
    Nazarii Vovk
    Threads: 11
      Also, how should I name previews (multiple images) of the model to be picked up by PM in version 3 ex. “chair.jpg, chair1.jpg, chair2.jpg”?
    • #17833
        Main preview will be applied auto. Other files you can add manually.
        Thanks for idea.
Viewing 6 posts
