- June 13, 2018 at 13:10 #16081
Kinower
GuestPosts: 13Threads: 20Joined:::Hello, I would like to make several suggestions for possible updates.
-Can excludes certain folder or in any case exclude folders named as “maps”
-The action of double click to be able to decide; merge or open the preview and put it by default, or put a shortcut to preview image. I often use the preview
– Another possibility is that the miniature appears in large when the mouse passes over the asset
-Add some dialog to max to add an asset directly to project manager or to drag and drop an asset to the project manager
-Possibility to put watermark in the preview with the asset render enginethank you and continue with this delicious script
- June 13, 2018 at 13:36 #16083
ModeratorPosts: 264Threads: 1285Joined: Aug 2009-Can excludes certain folder or in any case exclude folders named as “maps”
Thanks for the idea – I will be added this to the wishlist
There is two solutions for this:
1) Use the menu item “Open with” like on the picture below:2) Using Project Manager’s API
I prepared an example script for you:
Download example script: Display thumbnail
Here you can see how to add it on the toolbar
