Viewing 7 posts
  • #33556
    j.a.b
    Threads: 3
    Plugin version: 3.15.79
    3ds Max version: Max 2021. sp3
    Renderer: Vray
  • #33566
    Threads: 1225
      Hello
      Are you using some software for managing monitors?
  • #33567
    j.a.b
    Threads: 3
      No
  • #33568
    Threads: 1225
  • #33581
    j.a.b
    Threads: 3
      I have tried generating a support request however the window just gets stuck on ‘Cancel’. Can you confirm you have received a request?
    • #33582
      Threads: 1225
        Hello.
        I’m didn’t receive anything.
        Maybe antivirus or firewall blocks sending.
        The archive should be located in the directory %temp%.
        You can send it manually to support@3d-kstudio.com.
  • #33585
    Threads: 1225
      This occurs when a window is partially located outside the screen.
      This issue will be resolved in the next update.
Viewing 7 posts
