Viewing 6 posts
  • #15656
    Michal Ziobro
    Threads: 40
      Alex,
      If i copy material from selection and apply it – PM saves only UV mapping (ignore modifiers like Vray displacement)
      Best regards,
      Michal
  • #15657
      Modifiers like vray displacement have to use material like on next image.
      So “Use object mtl” option must be on or texmap must be use in material
      Save V-Ray Displacement Modifier with material
  • #15658
    Michal Ziobro
    Threads: 40
      True, i didnt notice i got use object mtl unchecked. Thank you
  • #15659
    Michal Ziobro
    Threads: 40
      But if i plug texmap it doesnt work,
      For use object mtl – no problem
  • #15660
      This texMap also must be use in saved material.
      There is no sense to save modifiers that doesn’t depend to material.
  • #15661
    Michal Ziobro
    Threads: 40
      Yes works now i had copy instead instance – sorry for that:)
Viewing 6 posts
