Viewing 7 posts
  • #22225
    Morten Olesen
    Threads: 5
      Hi.
      Is it possible to render for instance 3 angles of one model object at one go by hitting render thumbnail in PM3? For instance by using a custom studio with 3 cameras in them. I know that we can do this manually in PM3, but I would like to set up a studio where it render front, angle low and angle high and show them all in the pane to the right inside PM3.
    Plugin version: 3.07.31
    3ds Max version: 2019
    Renderer: corona
  • #22229
    Threads: 1285
      This feature already available in Project Manager.
      Create a custom studio with the desired number of cameras and views.
      Turn on the related checkbox in settings.
      Rendered thumbnails will be attached to the related gallery of max file and will be shown in the right panel.
      Render from multiply cameras
  • #22231
    Morten Olesen
    Threads: 5
      Great. That works fantastic. Awesome feature. When you have 3 thumbs rendered how do you choose which one of them will be the default one that is shown in the middle pane? By default, it’s the first one rendered, but sometimes one of the other angles might be better.
    • #22268
      Threads: 1285
        The first image in the gallery is used as a preview for the file.
        Use “drag & drop” to change the file position in the gallery.
      • #22481
        Morten Olesen
        Threads: 5
          Great, thanks.
  • #44003
    Andreu Cabot
    Threads: 4
      Hello,
      Is it posible to render multiple thumbnails for Materials also? Now its only posible for 3d Models (use all cameras in scene function)
      I am not able to render more than 1 camera / Studio. Do you know a way to do it?
      Thanks a lot
    • #44004
      Threads: 1285
        Rendering for multiply materials library is supported since first version.
        Just add files to Batch Render or render materials directly from Project Manager
Viewing 7 posts
