- October 27, 2023 at 15:23 #40019
Willian Auerbach
ParticipantPosts: 1Threads: 0Joined: May 2018Hi,
Lately, the Project Manager has been very slow when applying objects to the scene.
I’ve tried using the MysqlServer on Win Server, Win10, and Linux, but the problem persists.
Here’s the issue:
When I drag an object to the scene, it takes about 1 minute to import. When I use the Merge function in 3Ds Max, it takes 3 seconds.See a record of this case
Plugin version: 3.23.61
3ds Max version: 3ds Max 2024
Renderer: Corona - October 27, 2023 at 15:25 #40021
ModeratorPosts: 263Threads: 1215Joined: Aug 2009 - November 3, 2023 at 19:16 #40060
László Kerezsi
ParticipantPosts: 1Threads: 1Joined: Dec 2013Hi, same problem here. But if I switch from MYSQL to SQLite, dropping the models is working fast again with Auto relinking switched on. So the problem is with SQL, could you please fix it?
