  • #14814
    TORRI
      Project Maneger 2.88.06″
      does not work ! after last update.
      When I open the program I receive the message:
      –UnKnown property: “GetMaxFleFullPath * in undefined
      in maxscript Listener this script:
      “- Error occurred in GetDependentFiles(); filename: C:\Users\masi\AppData\Local\Autodesk\3dsMax\2015 – 64bit\ENU\scripts\TrackScripts\ProjectManager\AssetFunctions.mse; position: 3612; line: 61
      — Defined in encrypted script
      — called in GetDependentFiles(); filename: C:\Users\masi\AppData\Local\Autodesk\3dsMax\2015 – 64bit\ENU\scripts\TrackScripts\ProjectManager\Assets.mse; position: 1575; line: 31
      — called in ntEiRKl4EtVRBV4Oy+4uate7YtYv3xIuaBTEWmjXMi0=(); filename: C:\Users\masi\AppData\Local\Autodesk\3dsMax\2015 – 64bit\ENU\scripts\TrackScripts\ProjectManager\Assets.mse; position: 7684; line: 122
      >> MAXScript dotNet event handler Exception:
      — Unknown property: “GetMaxFileFullPath” in undefined <<“”
    Plugin version: 2.88.06
    3ds Max version: 3d studio max 2015
    Renderer: Vray 3.60.4
  • #14815
      Completely uninstall the Project Manager and install again.
      Please use version downloaded from 3d-kstudio.
  • #14829
    TORRI
      Problem solved.
      The plugin is fantastic. I could not work without this plugin.
      Thanks for your constant work
  • #14839
      Thanks for your feedback, Torri!
