- March 5, 2020 at 07:28 #26969
Man Mars
ParticipantPosts: 9Threads: 12Joined: Dec 2019Hi,
If I merge model with “Merge as Proxy” unchecked, everything’s fine. But if it’s merged as proxy, there is problem with its material. Also Corona converter didn’t work with this proxy. This problem does not happen ussually, but in some cases. I ‘m not sure, maybe only with objects with too complicated texture?
Plugin version: 3.08.81
3ds Max version: 2018
Renderer: Corona - March 5, 2020 at 07:33 #26971
ModeratorPosts: 262Threads: 1193Joined: Aug 2009Hi
For 1st please try to merge and convert this model to proxy manually. If it works then generate the bug-report and attach the original file, his proxy, and related material file.
