- April 18, 2015 at 12:45 #9805
Reinaldo
ParticipantPosts: 1Threads: 4Joined: Apr 2015i just upgraded to the newest version 2.14.20
i cant render the ies. i havent tried to render the ies using the previous version tho. just bought 6 licenses and just tried it today.
rendering the thumnail of 3d model works fine. but not on ies. havent tried the material.
i checked on the setting, and i already change the custom studio on material to ies.max
i use vray and already set the setting to vray as default.
- April 18, 2015 at 14:19 #9806
ModeratorPosts: 264Threads: 1283Joined: Aug 2009What you mean not work?
You receive a black image in output ?
The IES now has only one parameter – thumbnail size.
Soon i will add the ability to change the intensity multiplier. - April 19, 2015 at 06:12 #9807
Reinaldo
ParticipantPosts: 1Threads: 4Joined: Apr 2015it always freeze the 3dsmax and ask the 3dsmax to close and then kick out. it always happened half way the rendering. it only happened with the newest update.
i tried the previous installer on my other workstation (i have 6 licenses btw) and it works just fine.
yesterday i also tried to render material this is the scenario :
1. i havent render any thumbnail, so it still the default preview from the PM
2. i render 1 of the material on my metal library (i have 10 kind of metal material inside it) and it works fine
3. then i tried to render the thumb of 2nd material, it render, but once it finish rendering, the 3dsmax kicked out. first i thought it because i use my own material studio scene, but apprently using ur material.max also happened the same way.
any advice ? can you check if this something wrong with the newest update ?
coz i really need to setup my library here.
- April 19, 2015 at 17:27 #9808
Reinaldo
ParticipantPosts: 1Threads: 4Joined: Apr 2015i sent u a video directly to support and ur email.
just in case u are not getting it please download it
- April 20, 2015 at 16:25 #9809
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Thanks for video.
I did not make any changes, related to rendering the thumbnails.
It seems that error with computer, windows or 3ds Max.
Try a next:
Create the Free Light manually and assign the IES file to it.
I think after this the 3ds max will be crash.
