- March 18, 2025 at 19:03 #44293
15810142059a
ParticipantPosts: 1Threads: 5Joined: Mar 2025Hello, based on my testing, the plugin doesn’t seem very friendly with Arnold.
When using thumbnails, specifying the use of the Arnold renderer always fails.
Is this the case?
- March 18, 2025 at 19:07 #44296
What is mean “fails”?
What version of 3ds max and Project Manager are you using?
Could you please describe more about the problem? - March 19, 2025 at 03:13 #44308
15810142059a
ParticipantPosts: 1Threads: 5Joined: Mar 2025When rendering Arnold material thumbnails, instead of generating sphere thumbnails, flat, solid-color thumbnails are produced. With ‘use custom studio’ enabled, and only an Arnold area light used while specifying Arnold to render the model thumbnail, only a flat black image is generated (using default lights or V-Ray area lights works normally). These issues do not occur when I specify V-Ray as the renderer. The software I used for testing is 3ds Max 2025 with Arnold 5.7.8.0 and 3ds Max 2023 with Arnold 5.7.7.0. The plugin version is 3.37.86.
- March 20, 2025 at 02:52 #44315
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Please try version 3.37.90
Thanks for your feedback. - March 20, 2025 at 03:51 #44317
15810142059a
ParticipantPosts: 1Threads: 5Joined: Mar 2025Thank you very much for your proactive improvements. Your team has done a great job. After my initial testing, the material thumbnails work fine after rendering the specified Arnold rendering thumbnails. However, the model thumbnails still don’t work very well. I will conduct more tests later. The testing software is 3ds Max 2025, Arnol
d 5.7.8.0, and the plugin version is 3.37.90.
- March 20, 2025 at 03:55 #44319
15810142059a
ParticipantPosts: 1Threads: 5Joined: Mar 2025https://drive.google.com/file/d/16SsEF6cHaqN7Bpi6o1XiZsvPaNwJCEnP/view?usp=sharing
Above is the link to the test model file
- March 20, 2025 at 15:06 #44321
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Try version 3.37.91
Please note that if textures are not found, you may also get black renders. In some cases, relative paths will also not be accepted as valid.- March 20, 2025 at 15:18 #44322
15810142059a
ParticipantPosts: 1Threads: 5Joined: Mar 2025The plugin has been updated to 3.37.91, and there are no more errors. Thank you very much for your team’s efforts, you’re doing a great job.
- March 20, 2025 at 16:12 #44324
ModeratorPosts: 264Threads: 1283Joined: Aug 2009You’re very welcome!
