Viewing 7 posts
  • #30749
    lingrenddd
    Threads: 10
      I am using Project Manager to organize my model library, and I found that after finishing it, I use Project Manager to import the organized model into 3ds Max, and the textures are all lost. But I opened those model source files and the textures were there. I want to know what the reason is and what needs to be paid attention to when organizing.
  • #30751
    Threads: 1193
      So as I understand, you copied or moved max files to a new location. And these files use relative paths.
      Am I understand correctly?
  • #30752
    lingrenddd
    Threads: 10
      Yes! I think I found the solution, which is to add the MAPS path in “configure project paths/External Files”, right? Thank you!
  • #30754
    Threads: 1193
      Yes – this should help.
      But don’t add a lot of paths in this dialog.
      Another solution – is using the Batch Relink tool for relinking paths.
  • #30755
    lingrenddd
    Threads: 10
      OK! Thank you!
  • #35825
    Muhammed Ridha
      Hello, when I drag material in the material editor it will be black and miss the textures.
      How can I fix it?
Viewing 7 posts
