  • #38913
    Carlos Leon
    Threads: 0
      Hello, i am having some trouble when I am making some thumbnails. The problem is only with some scenes or objets, because in some thumbnails is doing correctly but in others do not. I make a simple scene with a floor and a white backgroung aroung the dummy object in the thumbnails studio scene and in some scene displace the floor  in Z direction, and cover some of the object. I attatch the example that what is going on in here.
      Thank you
    Plugin version: 3.20
    3ds Max version: 3dsmax 2022
  • #38915
      Hello
      1. Check if the pivot of SceneDummy is located at the bottom
      2. Try to override the pivot for models in the render settings
