Viewing 6 posts
  • #20657
    shawnolson
    Threads: 6
      I suddenly cannot use PM. When I try to launch it I new get this MAXScript error:
      — Error occurred in anonymous codeblock; filename: C:\Users\smols\AppData\Local\Autodesk\3dsMax\2020 – 64bit\ENU\scripts\TrackScripts\ProjectManager\Main.mse; position: 1032; line: 17
      — Runtime error: .NET runtime exception: Object reference not set to an instance of an object.
      — MAXScript callstack:
      — thread data: threadID:16296
      — [stack level: 0]
      — In anonymous codeblock; filename: C:\Users\smols\AppData\Local\Autodesk\3dsMax\2020 – 64bit\ENU\scripts\TrackScripts\ProjectManager\Main.mse; position: 27853; line: 310
      —  Defined in encrypted script
      — [stack level: 1]
      — called from execute(); filename: C:\Users\smols\AppData\Local\Autodesk\3dsMax\2020 – 64bit\ENU\scripts\TrackScripts\ProjectManager\Main.mse; position: 1033; line: 17
      — member of: codeblock macroScript: Track_Project_Manager
      — [stack level: 2]
      — called from codeblock macroScript: Track_Project_Manager
      —  Locals:
      —  Externals:
      — [stack level: 3]
      — called from top-level
    Plugin version: 2.96.46
    3ds Max version: 2020.1
    Renderer: Scanline
  • #20659
    Threads: 1282
      Please try to remove settings.
      Main max menu “Project Manager” => “Open plugin’s folder”.
      Remove all ini and xml files  excerpt the “Version.ini” file in the directory “Settings”.
      Restart 3ds Max.
      If this will not help please find me in skype as alexkstudio.
  • #20660
    shawnolson
    Threads: 6
      Thanks Alexander. I tried this and it isn’t working. The same problem manifests.
      I wonder if this relates to recent Windows Updates?
    • #20663
      Threads: 1282
        Please check your skype.
  • #33671
    Jonathan Tan
      hi i have the same issue
      any solution for max 2022
    • #33677
      Threads: 1282
        Maybe you must upgrade Project Manager to version 3
Viewing 6 posts
