- September 28, 2022 at 23:15 #36733
Gethin Hooper
ParticipantPosts: 12Threads: 6Joined: Jun 2019I’m trying to batch run a script on hundreds of files -some of which have corruptions triggering 3dsmax security tools. If I open the files manually, security tools asks if I want to clean the file and re-save. Done. No problems. If I run batch render-relink to run the script only, it crashes out on these files. My script is simple script to remove animation layers which are slowing my system down. Is there a way to add the .net event or close the security tools window as part of the batch process?
3ds Max version: 2021
Renderer: corona - September 28, 2022 at 23:16 #36753
ModeratorPosts: 263Threads: 1210Joined: Aug 2009Just fix these files before batch processing
