- August 28, 2020 at 22:23 #29078
jagarzor
ParticipantPosts: 1Threads: 1Joined: Jan 2019Hi all!!. I have a directory with 20 3d models and I want to move 10 of them to another directory.
If I use the cut/paste option that action also affects the files on my hard drive.
I just want those 10 thumbnails to be moved to another directory so it doesn’t affect my hard drive files or their maps.
Do you know if it is possible to do this action? Thank you all!!!Plugin version: 3.11.55
3ds Max version: 3ds Max 2019
Renderer: Corona Render 5 - August 28, 2020 at 22:25 #29082
ModeratorPosts: 264Threads: 1276Joined: Aug 2009I have a directory with 20 3d models and I want to move 10 of them to another directory…I just want those 10 thumbnails to be moved to another directory
So you want to move thumbnails or models?
- August 29, 2020 at 00:21 #29083
jagarzor
ParticipantPosts: 1Threads: 1Joined: Jan 2019Sorry, i want to move only the thumbnails.
- August 29, 2020 at 16:35 #29087
ModeratorPosts: 264Threads: 1276Joined: Aug 2009- Turn off the filter
- Select and move the desired image files
- Link your 3d models with moved images if required. Use the “Auto-Assign” tool
For moving thumbnails to another directory:
