- February 12, 2019 at 12:58 #17727
Arild Karlsen
ParticipantPosts: 1Threads: 0Joined: Feb 2017Hi,
I’m having a error popup window each time I try to use add folder in batch Rename tool of Project Manager. In the past everything worked great but after update to leatest Project Manager that issue is always present.
How I can fix it?
Please helpmy system :
3ds Max 2018.4 – 20.0.-20.4.0.4254
Operating System: Windows 10 Pro – Version 10.0.17763 Build 17763I can attached details raport from this Microsoft.NET Framwork error if that will be helpful
Plugin version: 2.94.76
3ds Max version: 3ds Max 2018.4 - 20.0.-20.4.0.4254
Renderer: Vray 3.60.04 - February 12, 2019 at 13:23 #17729
ModeratorPosts: 264Threads: 1284Joined: Aug 2009Please try restart 3ds Max and test again.
If problem isn’t solved please generate the bug report and attach the details from the dialog “Microsoft.NET Framework”.
You can generate the bug report from the menu “Project Manager” ==>> Create support Request.
- February 12, 2019 at 20:02 #17735
ModeratorPosts: 264Threads: 1284Joined: Aug 2009- change used Windows Theme to default and restart windows
- update Windows to latest
Solution:
