Viewing 13 posts
  • #39574
    Threads: 21
      Hi, we are having problems with PM when merging any kind of object, small or heavy ones, it takes a lot of time for them to merge when using PM, if we merge them with max default its quick.
      Default max merge : 2 seconds
      PM merge with double click: 7 seconds  same with drag and drop from PM 7 seconds
    Plugin version: 3.23.11
    Renderer: 2023.3.3
  • #39576
      Could you please create a video of the process of merging with Project Manager and with the default 3ds max dialog?
      Please restart 3ds max between sessions. Merging the same model on the same session a second time might be faster, so restarting 3ds max will allow us to evaluate the time.
      Please also send this video and a few of these models to support@3d-kstudio.com
      Thanks for your feedback
  • #39577
    Threads: 21
  • #39578
      Please also send a few from these models to support@3d-kstudio.com
  • #39579
      Renderer: 2023.3.3
      Did you mean, maybe, the 3Ds Max version?
      The latest 3ds Max 2023 version update is 3.4.84
      Try to install the latest update for 3ds Max
  • #39582
      How hard is this scene?
      Is this occur in any scene or only some?
      We also should include time to show a dialog for merge. It is nearly one second.
      Also, note that checking the assets in use also affects the merge time.
      In the future, I’ll add an option to disable auto-relinking on merge.
  • #39583
    Threads: 21
      Hi Olexsandr
      Here is the information you asked for:
      Our 3dsmax version is (as about tab 3dsmax says)  2023.3.3 Security Fix  25.0 – 25.3.3.6012
      The scene is a new 3dsmax scene, empty
      It happens on all scenes
      Looking forward for those upgrades.
      Will send those models with its textures, and upgrade to the service pack 4
  • #39703
    Threads: 21
      Hi Alexander
      Sorry for the long delay.
      Here is a model with its assets and a new test, I try Project manager, Free Connecter and max default, results are Pm 11 seconds, Free Connecter 4  and max default 2 seconds.
      https://we.tl/t-ZBRLrc5FD7
    • #39704
        What number of folders are in the folder “Vase”?
  • #39705
    Threads: 21
      There are 45 folders inside Vase folder, there are no isolated objects inside the Vase folder, just the 45 folders
  • #39712
      Try version 3.23.30
      Turn off the option “Auto-Relink Missing Assets ”
      You can download the latest version from the dashboard.
  • #39713
    Threads: 21
      Alex you are a genius! Time went from 11 seconds to 3 !
      Its a great time saver, THANKS !
      a lot of the missing assets on the models came from “fake” render elements that the model still searches but are 100% not necessary for the models.
      Thanks again!
    • #39717
        Perfectly!
        Thanks for this feedback!
        Interestingly, on my computer, this option almost did not change the time of merging
Viewing 13 posts
