- February 18, 2024 at 19:22 #40946
Rossen Mitov
ParticipantPosts: 10Threads: 9Joined: Jan 2015Hello,
3ds Max crashes, if I’m using the light 3ds Max theme and then I open Project Manager (which is set to dark theme). I have a 3dsmax_minidump.dmp that I can send, if you need it.
Plugin version: 3.23.70
3ds Max version: 2023.3.3
Renderer: V-Ray 6 Update 2 (6.20.02) - February 18, 2024 at 19:23 #40951
ModeratorPosts: 264Threads: 1283Joined: Aug 2009Apply the desired theme and restart 3ds Max.
It crashes only if you switch the theme on the CUI tab Colors and then start the plugin.
It works if you start the plugin and switch the theme after this.
Or restart 3ds max after switching the theme.[Resolved]
- February 18, 2024 at 19:28 #40952
Rossen Mitov
ParticipantPosts: 10Threads: 9Joined: Jan 2015Got it. Thanks for the quick reply!
