Viewing 11 posts
  • #41728
    lingrenddd
    Threads: 10
      Hi!
      Use Project Manager to import models, and the texture is often lost. I know that the MAPS path can be added in Configure Project Paths, but some models have a MAPS folder in each collection, such as MaxTree. If you add one by one, too much. Is there any solution?
  • #41731
    Threads: 1225
      Just turn on the option “Auto-Relink Missing Assets”
  • #41735
    lingrenddd
    Threads: 10
      After the setting is completed, I need to restart MAX? I just set it up and found that I still lose the texture
  • #41736
    Threads: 1225
      Textures will be find automatically only in case if them located near the model.
      In other case you can use Batch Relink tool to relink textures before using
  • #41737
    lingrenddd
    Threads: 10
  • #41738
    lingrenddd
    Threads: 10
      MAPS is indeed nearby
  • #41739
    Threads: 1225
      As I see the autorelink option for models is still off
  • #41740
    lingrenddd
    Threads: 10
      It looks like my setting is the same as yours
  • #41741
    lingrenddd
    Threads: 10
      I hooked this option, and now the problem is solved
      [Resolved]
  • #42147
    Kovacs Balazs
      hi, I have the same problem, but the miscellaneous looks different
    • #42148
      Threads: 1225
        Because you are using an old version
Viewing 11 posts
