- November 17, 2021 at 23:14 #33905
Richard Throgmorton
ParticipantPosts: 1Threads: 2Joined: Nov 2021I just bought and installed Project Manager v3. When I start 3ds max 2021 it crashes to the desktop immediately upon start up. I’m trying to uninstall it to see if PM3 is causing the problem but I can’t do it through the Max UI menu. How do I manually uninstall it?
Plugin version: 3
3ds Max version: 2021 - November 17, 2021 at 23:14 #33907
ModeratorPosts: 264Threads: 1282Joined: Aug 2009Strange, because, Project Manager almost doesn’t load anything when starting 3ds Max.
To removing startup scripts, just delete the file “%localappdata%\Kstudio\data\Callbacks\KstudioCallbacks.mse”
and KstudioSaveStudioFile.mse and ProjectManager_3.ms from the user startup scripts.
Find me tomorrow on skype as alexkstudio, if the problem still persists - November 17, 2021 at 23:57 #33909
Richard Throgmorton
ParticipantPosts: 1Threads: 2Joined: Nov 2021Thank you for the help. I uninstalled it but the crashes do not seem to be associated with the Project Manager.
- November 24, 2021 at 18:37 #34020
Richard Throgmorton
ParticipantPosts: 1Threads: 2Joined: Nov 2021After several days, and re-installs, I finally managed to get Max running correctly. PM is installed and there have been no issues so far. Actually, the first use literally doubled the value of what I paid for it.
Question: Is it possible to add menu categories to the left vertical options? I am talking about the Models/Materials/Textures/IES menu.
