Viewing 8 posts
  • #27680
    Threads: 4
      i have a problem, when i drag a simple model in my max scene everything is fine,
      but if a drag a model that have inside one object repeated more times with different textures variation,
      for example tha same chair with different wood variations, see the file attached right side
      when i drag in the scene, i have just one texture variation..file attachde left side …
      how can i do to fix it?
    Renderer: corona
  • #27682
      Hi
      Are you have the same issue after rendering or only into viewport?
      Please generate the bug report and attach this max file.
  • #27685
    Threads: 4
      tahnks for you reply,
      sorry but i did a bit of confusion: left side is the original file, chair model with different color variation,
      right side appear just one color when i drg the file from Project Manager,
      i’ll try to render later
  • #27688
    Threads: 4
      i ogt the same problem if i try to render the object imported with Project Manager,
      should i split the model  in differents files? (example each file one color variation) but this will take a lot of time, not a nice workflow
      i generate the bug report
  • #27689
    Threads: 4
      In my library, that i’m starting to use in Project Manager,
      i have a lot of model where in one single 3ds max file i have the same Design Obejct but repeated more times with different texture and color variations.
      for example if you check the image attach,
      -left side Blu_Dot_Field…..you can see as the same model has different fabric variation.
      -The Problem is: when i drag th model from project M. into a max scene, i get I get just one variation, and not able to see the other colors/Texture variation ;(( also i get everithing as a group and not separated objects.
      The solution could be split the file in more files but this will increase my time workflow.
  • #27690
  • #27699
    Threads: 4
      Hello thank you for the reply!
      yes in this way works perfectly thank you!
      if i want to import with “the merge as a proxy” how could i do?
      with SHIFT or double click make a singol “big” proxy with all the variation inside, but to be abel to select one should i convert everything in a mesh ?
  • #27705
      In your case, you should convert to proxy manually, after merging a model.
Viewing 8 posts
