  • #9953
    tschuelke
    Threads: 2
      Hi
      a smal Question..  When i drop an Object  for example a Xfrog tree to my scene, and change the material for example from Standartmaterials to Vray materials or change geometry…
      is there a “one-klick” solution to save these changes back to my libary object ?
      thanks
      Tom
  • #9954
    Threads: 1285
      Use “Save Selected”
      Save Selected 3d model
  • #9955
    tschuelke
    Threads: 2
      Thanks…
      i allready found this.  But as i have seen , you Still need to specify the path and the name, to save it . Right ?
      is there a way, to do this with on cklick ?  Some sort of shortcut, as fast as dropping an libary object to the scene ?
      thanks
  • #9956
    Threads: 1285
      Path in file dialog equals to current path in Project Manager and file-name equals to the model name.
      As a rule you simple can press the ENTER key.
      So it’s looks very simple – press the button “Save selected” and press the ENTER key.
      Save selected- file_dialog
      Also as bonus – using this dialog you can specify a version of 3ds max for saving.
      Save selected - file_dialog with addiobal options
