Viewing 13 posts
  • #36069
    Thomas C
    Threads: 45
      Hi Oleksandr,
      I hope you’re well and safe.
      Thank you for Project Manager I love it and use it all the time on every project :)
      When I drag and drop textures in the Slate Material Editor from the Textures panel, it creates a new material. That’s fine, no problem.
      But I don’t know how to simply drag and drop textures without creating a material: sometimes I just want to drag and drop textures in the Slate Material Editor, I don’t need to create a material out of them.
      I tried to drag and drop textures while pressing the Shift key: 3ds Max crashes.
      Thank you for the help Oleksandr.
    Plugin version: 3.18.34
    3ds Max version: 24.0 - 24.3.3.3511
    Renderer: Corona 8 Hotfix 1
  • #36071
    Threads: 1216
  • #36074
    Thomas C
    Threads: 45
      Thank you Oleksandr.
      It works if I drag and drop one texture at a time, but not if I drag and drop multiple textures at the same time.
      Do you confirm?
  • #36077
    Threads: 1216
      This works the same for multiple bitmaps/maps as for single
  • #36079
    Thomas C
    Threads: 45
      It doesn’t work for me: when I drag and drop more than one texture and press Shift key, 3ds Max crashes.
  • #36080
    Threads: 1216
      Please try version 3.18.38
      Auto-updater will be triggered in a few days if there’s no critical issue found
  • #36086
    Thomas C
    Threads: 45
      I can’t find version 3.18.38 on my dashboard: there are two download buttons, I tried both of them but when I drag and drop the .mzp in 3ds Max it says “Project Manager 3.18.34”.
      How can I download 3.18.38?
      Thank you Oleksandr
  • #36087
    Threads: 1216
  • #36088
    Thomas C
    Threads: 45
      Sorry … too much work, I don’t see anything.
      Thank you.
  • #36089
    Thomas C
    Threads: 45
      So I installed v3.18.38 and it works.
      But it doesn’t seem stable: I had 3ds Max crashing when drag and dropping VizPeople textures.
  • #36090
    Threads: 1216
      Please generate the support request and attach one directory with VizPeople textures.
  • #36091
    Threads: 1216
      Also please update to Corona 8 Hotfix 2
  • #36092
    Thomas C
    Threads: 45
      Since I updated to Corona 8 Hotfix 2 I am no longer able to reproduce the issue. All good  :)
      Thanks for awesome support.
      Keep safe,
      Tom
Viewing 13 posts
