- March 4, 2022 at 15:20 #34868
Victor Larsson
ParticipantPosts: 3Threads: 8Joined: Nov 2021Hi,
Im having some problems using the batch relink and renderer. Sometimes or often my max resets to gamma 1.0 after the Batch relink and render even though its set to 2.2 in both my preference and render scenes. Gamma Output is however set to 1.0 in Project Manager so the jpg doesnt have incorrect gamma on thumbnail save.
Its kinda annoying to have to fix these evertime. Would have been much better if it could stick to the gamma used before. Same problem on my other machine.
Plugin version: 3.17.41
3ds Max version: 2021 Latest
Renderer: Vray - March 4, 2022 at 15:24 #34878
ModeratorPosts: 263Threads: 1244Joined: Aug 2009Could you please make a screenshot of your usual Gamma settings?
And write what exactly settings are changing.
Is that happening after rendering or after relinking? - March 4, 2022 at 15:43 #34879
Victor Larsson
ParticipantPosts: 3Threads: 8Joined: Nov 2021I attached the settings in my Max how it looks like before rendering the thumbnail
This is how it looks like after rendering is done. The renderscene has 2.2 as gamma.
I could force this in a startup gamma script on my local pc but I think it should be handled with the plugin to read the gamma of the scene before rendering and then apply the same gamma on end? - March 8, 2022 at 18:40 #34893
ModeratorPosts: 263Threads: 1244Joined: Aug 2009This issue is fixed in version 3.17.54
