  • #43031
    Ho Viet Bao Minh
    Threads: 2
      I rename a bunch of objects, then drag and drop them into the viewport to use, but why aren’t their names changed when I use Advanced File Renamer? The old versions worked fine, but the versions v3.35.85 – v3.36.10 don’t rename as expected. Please check for me. Thanks team.
    Plugin version: 3.36.10
    3ds Max version: 3dsmax 2025
  • #43037
      The Project Manager is designed to maintain the original structure of objects during import, including their names. This behavior prevents changes to object names to ensure consistency across files.
      However, when models containing multiple objects are imported using the drag-and-drop method, these objects are grouped together, and the group name is assigning by the file name.
      This could explain why you’re seeing the previous names even after using Advanced File Renamer.
  • #43039
    Ho Viet Bao Minh
    Threads: 2
      I will redownload the lower version to get the functionality I need. Thanks for your reply.
  • #43042
