  • #9786
    Hernando Ramsis
      Suddenly I cannot open Project Manager, even thought I already reinstall it.
      I got error like this:
      — Error occurred in anonymous codeblock; filename: C:\Users\Hernando\AppData\Local\Autodesk\3dsMax\2015 – 64bit\ENU\scripts\TrackScripts\ProjectManager\Main.mse; position: 3673; line: 106
      — Defined in encrypted script
      — Error occurred during fileIn in “C:\Users\Hernando\AppData\Local\Autodesk\3dsMax\2015 – 64bit\ENU\scripts\TrackScripts\ProjectManager\Main.mse”; line number: 106
      — called in execute(); filename: C:\Users\Hernando\AppData\Local\Autodesk\3dsMax\2015 – 64bit\ENU\scripts\TrackScripts\ProjectManager\Main.mse; position: 752; line: 12
      — called in anonymous codeblock
      — Frame:
      >> MAXScript MacroScript Error Exception:
      — Cannot assign to read-only variable: IES <<
      Thank you,
      Nando
  • #9787
      Please generate the bug report (utility menu “Help” ==>> “Create support Request”
  • #9788
    Hernando Ramsis
      Bug report sent,
      Thank you
