Viewing 7 posts
  • #22802
    Threads: 21
      Hi, we are using the new version 3, on version 2 we can drag a hdri file holding shift, but we cant drag hdris on version 3 anymore, it just comes as bitmap file.
    Plugin version: 3.07.52
    3ds Max version: 20
    Renderer: corona
  • #22807
    Threads: 1187
      Maybe you mean the CoronaBitmap because you use the Corona Renderer.
      For creating the VrayHDRI map you should switch your renderer to VRay.
  • #22813
    Threads: 21
      Hi alex, yes we use corona, and Pm 3, How can i drag an hdri that is in the material library to the material slots of max? previously we hold shift key and it will drag, but its not working anymore on Pm3
  • #22824
    Threads: 1187
      So if HDRI in a material library that means that HDRI already is part of some texturemap or material.
      For getting texturemap that depends on your renderer you must drag HDRI from the “Textures” tab.
      Could you make a short video for explaining exactly what you mean.
  • #22833
    Threads: 21
    • #22835
      Threads: 1187
        So
        You tried to drag a texturemap into MatEditor with SHIFT but instead the texturemap it creates a material.
        I wrote to you on skype.
  • #22837
    Threads: 1187
      As resume:
      Start dragging and only after starting drag press and hold SHIFT key.
Viewing 7 posts
