- May 19, 2019 at 11:38 #18246
George Chianese
ParticipantPosts: 4Threads: 2Joined: Jun 2017How do you use this script with vray? I tried it and the result is a standard material with an empty diffuse slot. There is also an error reported. This could be quite useful If I can get it to work with vray materials.
Plugin version: 2.95.32
3ds Max version: 2019
Renderer: vray - May 19, 2019 at 11:39 #18264
ModeratorPosts: 263Threads: 1254Joined: Aug 2009Example scripts in the folder “presets” are provided only to demonstrate the capabilities of API and are not full-fledged extensions.
Use them to learn the capabilities of Project Manager’s API for writing your own extensions to suit your particular needs.
You can read more about API here https://3d-kstudio.com/faq-cat/maxscript-api/
